Re: using an omc tach on mercury?
On the OMC tach you may have 4 connections<br />1 for ground( to engine ground not boat ground) 1 for sender/ sensor, 1 for power 12 volts 9 from engine) 1 for light. Merc should have wires in harness for this , except for light. <br />Gray wire for sender,purple for 12 volt power,<br />black for ground. Tach should have slot for small screw driver to adjust for stator pulses. May work may not depends on ignition system om Merc, did not give year of motor,
