Using lifting eye
andy6374
Just wanted to make sure here.<br /><br />One of the bolts that secures the outer flywheel to its' center hub is broken off. Is it okay to lift this engine using the lifting eye? <br /><br />Damm that flywheel nut is sure holding on to alot!
Texasmark
Re: Using lifting eye
High tensile steel will readily hold 30+ thousand pounds per square inch. Your engine weighs in at like 500#. No brainer.<br /><br />Mark
