Using MityVac 6400 dispenser to add gear oil, 2006+ Yamaha
I use a $6 pump that screws into the oil container....seriously gouging
GA_Boater
Welcome aboard.
I never felt 5 bucks was big bucks for something only used once a year.
99yam40
OK, now I want to know what all it is squirting.
I never found another use for mine once it was contaminated with lower unit stuff
GA_Boater
Motor oil, ATF and other assorted lubricants. It's flushed with new lube before squirting. I'm not putting 10W30 in my transmission or ATF in my lower unit. :smile:
99yam40
OK, thanks for responding.
I just never found the need to pump any small amounts of the other stuff.
just pour into a funnel.
but then I do use a large syringe to add ATF to my tilt and trim
