UTV Crank...........
MTboatguy
Sure looks like a crank to me as well, what is wrong with it Wim? Albeit, the picture is a bit blurry?
GA_Boater
I see a lot of what looks like metal curlings on the wood under the casting.
WIMUSKY
Discoloration from heat. Bud ran it out of oil and seized it up. I just heard he is going to replace it... About 1k in parts, so far. He's going to try and fix it by himself with a little help..
rbh
If all that seized was the piston/rings and the crank and other parts did not get overheated IE the needle bearings- hone or bore and get a fresh piston and rings
MTboatguy
Boy haven't seen you around for a while, things good in your part of the world?
rbh
Got a new gig, my companys sitting idle for now 14 days on 5 off, not much time for a life but need to pay the bills- and you?
