Re: V-P Duoprop Spare
So I went from an Alpha to a B3. I was hell bent on having an extra prop set. then I looked in to what it involved in changing the props with the dual setup, and thought about how it would be very difficult in the water, and i thought about how the aluminuim props on my A1 would be damaged from anything touching them and the stainless will take a tonne of abuse and I thought about how there is no hub on DP setups and if you hit something hard enough to really damage the prop you are going to damage the drive and then I gave up on the idea of having an extra prop. If I take out my prop I am going to more than likely take out the drive and I don't really want to jump in the water and change it so Ill just call seatow or limp back to the dock.
