reelfishin
- Joined
- Mar 19, 2007
- 3,050
I picked up three motors today, one is a 25" shaft 135 hp V4 that has a bad miss and low compression on one cylinder, the other is a 20" shaft 115 hp in pieces, but with a new powerhead that caught fire due to an electrical short, and the third is a 25" shaft length 150 hp V6 that is tired but still runs.
My goal is hopefully to make one good 20" shaft length V4. The 135 runs but has a dead miss, the 115 had caught fire right after the new powerhead was installed due to a pinch wire and a fuel leak, and the V6 is just a well worn motor with an internal exaust leak, and several leaky gaskets. All are VRO motors, the 135 is the only one with a tag still on it. The 115 is an olive green in color. The 135 was originally white.
My question is if I reseal the 115 power head, can I use all the 135 hp bolt ons?
I need to end up with a 20" V4 motor, so I assume that I need to also salvage the mid section from the burnt 115?
Will the carbs and everything else work on the 115? I do plan to toss the VRO too. I prefer to premix for peace of mind, this boat's last motor died due to lack of oil due to a leaky hose.
The lower end on the V6 looks the same as the 135, but the 115 don't look as heavy?
The 115 has 155 psi compression on all 4 but I don't want to chance a leaky or burnt gasket from the fire. That motor burned pretty good and the power head is black and covered in soot. It doesn't appear to have gotten so hot that it damage the aluminum, but I don't trust the gaskets and seals. It actually looks like it would run as is if I replaced the wires and fuel hoses. The carbs, flywheel and starter are gone from the 115.
