V6 Bleed Hoses
chadbenton
When replacing bleed hoses on a Merc. V6, can I use vaccum hose or is there a special hose required..........
WillyBWright
Re: V6 Bleed Hoses
The inside diameters are very tiny. Vacuum hose is way too big. I've never seen hose as tiny as bleed hose in anything else. You can get kits with pre-cut lengths, or bulk by the foot. Your only source may be a marine dealer.
LubeDude
Re: V6 Bleed Hoses
It`s also a great Idea to spray some carb cleaner into the fittings when you change the hoses, they are known to plug up.
