kwoolard
- Joined
- Feb 9, 2003
- 420
Guys,
This nice weather we had this past weekend forced me to get my boat out of winter storage. Over winter I bought a MityVac single brake bleeding kit that comes with a vacuum gauge you can use for engine diagnostics. Anyway, hooked it up to my engine and the only accessible spot, other than removing a plug on the manifold, was the PCV connection at the base of my carb.
I got good vacuum at idle 18" Hg, and revved the engine and vacuum increased to 23" Hg, give it a couple of throttle pumps and the vacuum drops close to zero back up to 21" and then steadies back out at 18" Hg.
The only thing that I noticed no matter what vacuum reading I was getting, the needle filckered very very fast(probably 10 times a second) over the small range of 1" Hg. As I revved the engine the flickering was still there but was so fast it looked like I had a needle that was wide enough to cover the 1" increment.
So my questions are:
1) Is the PCV port on the base of the carburetor a good source of continuous vacuum?
2) Is this flickering of the vacuum gauge needle a indication of leaking valve guides, or is this normal valve overlap, or what is this representing?
3) Is this flickering caused by the location of my vacuum port (PCV Valve). Is this PCV port connected to both sides of the manifold or just one side and that is causing this flickering?
Thanks and sorry for the long post.
Keith
Keith
