I am still trying to get my 93 115 running after a carb rebuild. It won't idle unless I shoot fuel in with the primer solenoid and is lean at full throttle. I assume I have a vacuum leak somewhere. I have replaced all the hoses, etc. so I am left with the gaskets.
My carbs have the plastic bowls. When I first assembled the carbs, fuel leaked from the bowl gasket when I pumped it up with the primer bulb. I tightened the screws and now there is no fuel leaking out.
But I am not certain that there is no air leaking in.
Is there any trick to making sure I get a good seal on the bowl and idle air chamber gaskets? I used new gaskets on both and installed them dry per the OEM manual - no gasket sealer.
Any ideas are appreciated.
