Robert Ellis
- Joined
- Oct 17, 2011
- 82
Hi,
I've recently come to own a quantity of mid to late 60s evinrude/Johnson motors (33 & 40 hp). I've started working my way through them ... rebuilding the ignition system, replacing the impellers, adjusting the carbs etc etc.
My question has to do with the vacuum switch on the starboard side of the motors and the what I presume is some sort safety switch up above it along the armature plate. On several of these motors, the lead wire (which always seems to be very corroded ... flaking plastic sheathing etc) going to this 'safety' switch has been pulled off of the switch and permanently attached to a ground screw. These motors seem to run just fine with this configuration but I'm wondering what safety feature is being bypassed? I guess what I'm really saying is I don't understand this circuit (or the vacuum switch circuit for that matter). Could anyone help explain these circuits - using the simplest terms possible and advise me re these bypassed switches?
