I have just finished putting in a new water pump and all of the seals, gaskets and O-rings in the upper because it was getting water in it.<br /><br />My problem is if I pull a vacuum from the dip stick hole it will hold 15 hg but if I check it from the drain hole it will not hold, just a steady drop from 5hg. Any ideas where it might be leaking?<br /><br />Thanks.
