ronaldreagan
- Joined
- Sep 8, 2014
- 68
I have a 2004 Mercruiser 3.0 and that I rebuilt. Ever since, the engine pings / knocks. When I put the engine back together, I adjusted valves per the service manual. The timing has been adjusted, carb rebuilt, and high octane gas was used to try and work the pinging out and none of these were the solution.
After checking the compression again, I get 120 psi on each cylinder. Tonight, I took the valve cover off and spark plugs out, loosened the rocker arm nuts at each cylinder 1/2 turn increments and checked the compression in between increments. The compression improved to 135 psi on the first 1/2 turn, then 150psi on the second half turn.
The concern is when I check the rod play at the recommended engine position it seems so excessive that I would not want to run the engine unless I knew it was adjusted properly.
Here are the two questions:
- How do I adjust the valves on a Mercruiser 3.0?
- Could bad valve settings cause the pinging / knocking?
Any advice on properly adjusting the valves would be great!
