valve question
b0mbtrack
i've got two different books telling me two different things.
i've got a 4.3l LX Vortec engine one book tells me to torque the valves down to 22' lbs while the other book tells me to go one turn past no lash. any idea which one it should be
model number from engine is OK010261 it is a 1997 hull
Don S
Re: valve question
What books are you reading?
According to the OEM manual, you torque them down to 20 ft. lbs.
It's easy to tell by just looking at the rocker arm studs. If they have a step in them where the threads end and the step is bigger in diameter than the threads, then you torque them, if the stud is the same diameter all the way down, the valves need adjusting.
b0mbtrack
Re: valve question
thank you, they do have a step. i am looking at both manual 7 and 25. #25 looks like the engine i am working on from the pics in the book where #7 doesn't. I will torque those down
thank you
Don S
Re: valve question
18 is the one you want, both of those are the wrong manuals for your engine.
b0mbtrack
Re: valve question
thanks don, i can't tell you how much i appreciate the help and how much time you saved me. unfortunately i am still having problems with this engine. i posted under new thread named whats going on.
