Valves clattering
BOAT DOCTOR
i have a 15c nissan four stroke had a valve sticking.tore head down cleaned,lapped valves,set clearances.motor runs fine but valves making more noise than before what could cause valves to rattle other than loose or tight valves
pvanv
Re: Valves clattering
Which valve was sticking? A stuck valve is a possible sign of poor lubrication. Either bad oil, a damaged/defective guide, or an overheating motor are likely... and could lead to a damaged stem. What clearances did you measure in the stem-to-guide? Any galling on the stems? What lash clearances did you set? What oil are you running? What is the actual oil pressure? What is the actual start-to-open temperature of the thermostat? Are the cooling passages in good shape? Is the water pump doing its job well?
