Owner's manual says "use 50 to 1 mix after long lay up. My questions - do you normally drain the vapor separator tank when winterizing so when starting first time after lay up, you can run fresh fuel at 50 to 1. How long do you run 50 to 1? I did not drain the vapor separator tank during the lay up. Fuel stabilizer added last time engine was used. Thank you all. <br />Alexc '03 150 ox66
