I'm in the process of buying a Chaparral 220 SSi, 5.7 Gi VP/SX. It currently has a 19P 4 blade Vensura prop. It's my first boat.
When I did the sea trial, I immediately felt like the boat had a bunch of bow rise out of the hole AND while on plane. Messed around with the trim at various speeds - didn't really settle the bow much (3 adults in the boat including 1 in the bow).
After the trial, did some research on this model Chap and found that other owners also felt the bow rise and plane speed were excessive so they installed smart tabs and solved both issues. They really like the smart tabs.
So then I start to do some reading on Mercury's site, other forums and iboats. I learn that the Vensura is known as an offshore, salt water, outboard, holeshot and bow lift prop. hmmm.
The questions:
The questions:
- Is bow lift considered a positive thing to reduce the amount of hull in the water while planing (perhaps to reduce friction) or?
- Why would a prop be considered an "offshore" prop?
- What happens if I add smart tabs? Will they be "fighting" the design of the Vensure prop - the bow lift aspect?
