vented gas cap
hondapapa
Should the gas cap be vented on a small outboard motor with the tank on it ?
Outsider
Re: vented gas cap
Has to be a vent of some description, most likely the cap ... ;)
F_R
Re: vented gas cap
Well it depends. Exactly what small motor are we talking about anyway?
hondapapa
Re: vented gas cap
It is a1969 sears eska 3.6 hp. It has a metal cap with no vent hole. May not be the right cap.
F_R
Re: vented gas cap
You may be correct. I can't say about that one. Are you having a problem with starving for gas? Just try loosening the cap to see if it helps. Then if it does, you will know.
