Ok, guys here goes, recently downsized from a 22' with I/O to a 16' with 40 hp OB. All is in excellent condition, motor runs great, my issue is the prop ventalates ( sorry if spelling is off) very easy. I can over come the issue with the power trin but boy is it fussy!! Cav plate is right at bottom of boat hull, boat is a Sylvan 16' side console. Motor is as low as it can go as far as be bolted to transom. Prop is a 10" dia x marked 13P ...there is 2" of clearance between blade tip and cav plate so a larger dia prop is possible...motor is a 40 hp Merc, 2 stroke 4 cyl, 1992 same as boat. Boat weighs 650 lb from factory specs plus 350lbs of batteries and gear.
( yep 3 lg group 31 bats plus starting battery). With 2 adults can just touch 30 mph (gps) at 54/5500 rpm wot. Must do some serious tweeking of trim to get that speed and stop ventalation. Question is, can I change/ modify a prop to lessen the vent issue? Serious trim alignment needs to be done to get her up and going without sucking air, gotta be on your toes so shedoesnt over rev. Mabey a cupped prop?? Thanks in advance folks.....
