Venting the prop ?
cloumar
The drilling of holes in the hub of the propeller, is it still a good tip for tuning and better take off performance ? <br /><br />Is it highly risky for the prop or it is OK if well done ?<br /><br />Smoky :confused:
bassin51
Re: Venting the prop ?
I drilled mine, 115hp Evinrude. It did seem to help, with the hole shot.
Jack Shellac
I vented a 15"p and a 17"p for my Johnson 88 Spcl. The 15" seems a little quicker to cavitate under full acceleration and I have to throttle back. The 17" does much better. Hole shot improved and no loss of top end. BTW, both are SS props.
cloumar
Do you believe on 75-HP Force with a 10.5'' dia. X 13'' pitch will help with the hole shot ?<br /><br />Thanks<br /><br />Smoky
zzzzz
venting adds air bubbles to the water making it "softer" and easier to push versus water with no air bubbles in it...thus a better hole shot...it should improve shot regardless of diameter or pitch :cool:
cloumar
And about risk for the prop, any or there is some ?<br /><br />Smoky
Jack Shellac
No risk to the prop. You can always fill it back in if you don't like it.
blueboat1
I have a 17' aluminum, with a 74 70hp Johson. i just got the boat and have been working on it. Jets/ h20 pump, head gasket etc.. Anyway last night was the 1st test run with the new jets/orifices, with the 14X15 prop with the vents drilled (it came with the boat as did 2 othere dinged up props) it just cavitaed like a mad man. I would mash the gas and have to back out in fear the motor was over reving. put on a 14X15 with no holes and it did better on take off but still only ran 24 mph. put the 14X19 back on no holes and it jumpoed up on plan and ran 34 mph. Vents didnt do got things here, could have also been the prop size. who knows how the 14X19 would have actied but at $129 a pop i wont be drilling any time soon.
MajBach
I did as much research as I could before attempting this. Unfortunately, i didn't find much out there. I have a 90hp 4 stroke on a 17' aluminum DC. I typically run a 19" prop which has a WOT @ about 5400; WOT range for this motor is 5000-6000. I also typically have rather heavy loads as I keep a fair amount of equipment on board. When it's just my wife and I, acceleration is adequate with this prop but I choose it because it is nice for cruising. Whenever I go out with a couple of buddies (extra few hundred pounds anyway), there is a lot of weight in the back of the boat, especially considering I have a 4 stroke and also with a full tank of gas. Planing can be a bit of a task here with the 19" prop. Without the 'Dol-Fin', I might night even be able to plane without filling front live well or standing up. But overall, my concern is with the load it places on the motor. Therefore, I often switch to the 17" prop I have. Typically, this means changing a prop every weekend or sometimes within the weekend.<br />For this reason, I wanted to experiment with venting the props. After researching abit, I drilled three 6mm (7/32") holes, at a small angle on the trailing edge of each prop; just like the illustrations on the links associated with this topic in this forum. Yesterday, I tried the prop on calm water with two couples on board and a full tank of gas. I immediately noticed a quick throttle response from idle when advancing the throttle slowly. However, there was very little acceleration. It almost seemed like I could run the motor at 1000 rpm or 2000 rpm and go the same speed. Advancing the throttle more into the hump yeilded a mushy feel. the motor definately sounded like it was spinning faster without a corresponding linear increase in speed. It alsmost felt like a spun hub. Actually, the best way i can think to describe it was like I had only 1 or 2 blades that were doing the work and the other one(s) weren't; it was a very unbalanced feel to it. The biggest surprise to me though was that even while planing at around 20 mph, a sudden increase in throttle seemed to also be lacking in an accompanying increase in acceleration; almost like the prop was still ventilating abit. The boat also seemed very bouncy, not porpoising but like I was in 1 foot waves even though there was absolutely no winds. I know a prop can make a difference in bow lift etc and was wondering if these holes were somehow change how the boat ran while underway. It was an open lake and there alot of very small rollers of inconsistent periods. But the boat just seemed very bumpy for the conditions.<br />I any case, i was quite unimpressed with the results so much so that I did not continue the trip without changing down to the 17" prop without the ventilation holes. Anyone have advice on what I observed? should I make the holes bigger ( No where have i seen drilling holes smaller than 6mm (7/32") as a astarting point). Is there a way to refill the holes without taking it to a shop?<br />Curious to know what others who have tried this have observed.
