Verado Fault code #9 /oil when fushing motor
Ryanepic
With my merc verado 175 ,While out in my boat motor would only go to 2000 rpms. Code #9 on gages said (engine power limited engine guardian is active reduce rpms) made it back to dock checked oil and it was low at the bottom of dipstick assuming this is why i had code. Then I also noticed a small amount of oil coming out of bottom of motor just enough to leave an oil sheen on water. When I connected factory flush on motor more oil came out just enough to have a sheen on water. Motor only had 56 hours and is 3 yrs old .
Ryanepic
Verado Fault code #9 and oil when fushing motor
I have a Mercury Verado 175 and Had a fault code #9 on my smart gauges that activated guardian mode allowing motor to stay under 200 rpms no matter what the throttle was set on when I made it back to the dock checked oil and it was low I believe this was the culprit. When flushing motor noticed oily sheen on water coming from the bottom of engine foot not sure if it's gas or oil . Would like to know where my oil went and why have oil coming out of foot.
