Verado New controls Dang!!
Stroub
I am in the process of repowering my 24 Roballo. I have installed the motor, ran the power steering and the new wiring harness. I have verified power at the accessory block on the continuous power. But no power at the accessory terminal purple wire even with key on. In turn no power to my vessel view or my digital throttle. I received the three pin harness. I connected the three pin plug (relay accessory power) to the harness (accessory relay) meter shows no power on accessory terminal. My junction box is a four plug box. It has the following plugged into it Bottom left Vessel View Bottom right Main wiring harness to motor. Top left Slim Binnacle throttle. Top right empty. I will take some pics if needed. I am wondering if they should have given me the ten pin accessory harness. I would greatly appreciate any suggestions ideas anything that I might do or try. If you need any pics I can get some and post them
