Re: very choppy on plain
Mercrude-<br />Is there a serious decrease in performance if you maintain the trimmed down position that you said rides perfect? With the weight you have in the boat, you might simply have to maintain that trim level to equilibrate the boat..... Also if you want adjustment ability, ,make sure the tilt adj. rod that mounts thru transom bracketr is on its lowest setting...that will allow you to trim motor further down for getting on plane and then trim up depending on planing speed and weight in/around on boat. good luck
