Very short dock lines
guy48065
I need to tie my pontoon as close to the end of my dock as possible because it's pretty shallow--esp. right now thanks to no rain. I've got the boat secured to the last 2 posts on my dock, against large plastic bumpers that keep it away from the steel wheels on this roll-in. The cleats shown are the only 2 on each side.
This is all to say I don't have many options on placement.
I'm using a short loop of ⅜ line at these posts. I like the boat close to the dock & not bucking around in the wind & waves, slamming it into the dock. I'm on a small inland lake, quiet here, level is dam-controlled.
Given all the above am I ok to use such short lines?
aspeck
Shouldn't be a problem ... from your description you shouldn't have enough wave action to do any harm ... as long as there are no large cruisers or houseboats that like to put out extra big waves ... or wake boats that like to harass docks ...
I would get rid of the dog collar snap clip
I personally like mooring whips vs the hard bumpers
Mc Tool
Do the plastic bumpers go up and down with the water level ....on a float ? Is the water level likely to rise without warning ?
Just thinking that limiting movement of the boat makes sense if your not going to get caught out. ......seen it happen in tidal areas 😂😂😂.
jlh3rd
looks like that rear hard plastic bumper top can contact the boat if it's rocked enough. I'd try to use my round air filled bumpers between the dock and boat, like in that gap.
I've also moved toward using bungee lines as tiedowns.
