SYCHOWAND
- Joined
- May 21, 2009
- 24
hi all am hoping someone can help me out with my johnson v4 90 circa 1990 serial # bj90tlesb please read on am at my wits end grrrrr so initial problem was a broken piston ring on no1 have fitted new piston and new rings to the other three and all relevent gaskets and seals and a new impeller kit for good measure! only to find after refitting the power head that it wont start it seems to be sparking on both starboard plugs a very weak spark on the lower port side and no spark on the top port plug obviously all were good prior to power head removal i have three wires which i am not sure where they go one is a short black with a round bolt on connector near the starter solonoid i imagine this goes to the earth post on the engine block there the other is also black with a round bolt on connector which comes in as a double cable with the main harnesses then splits via a bullit connector would also reach the earth post with a bit of persuasion this wire looks as if it could have lighter marks or a stripe! the third is a long green wire in a black shroud that reaches round to the thermostat hoses. if these cables are not the problem what could a complete layman like myself of done wrong or damaged? many thanks sorry for the long post lol ps when cranking it locks up if i over choke it is this normal or is something seriously out with the timeing? again many thanks
