heatzoneexpress
- Joined
- Feb 18, 2003
- 27
two questions. First, can i shorten the wire to my vhf antennae? ( it is damaged where it comes out of hull and goes to ant.)<br />question two is related to something i did yesterday that almost qualifies as a stupid human trick! In my haste to get her ready for the water i am installing a new depth finder. To remove the old one and related wiring I thought i would speed things up by hacking off the old transducer so i could pull the wire through the hole in the hull. Problem is, like an idiot I cut the tube for the speedo thinking(or not) that this was the transducer. I cut it about six inches up from the sender? unit. What i want to know is can i slide a slightly larger tube over both cut ends and silicone it? will my speedo work?
