VHF Radio Check
dnitz34
Can someone explain the procedure to perform a radio check before getting underway? Thanks.
Seon
Re: VHF Radio Check
Here in NoCal Delta ch 68 is the channel mostly used. Once launched and pulling out of the dock, I say, "Radio Check 68". When I get a response, I say, "Thanks for the come back".
Dunaruna
Re: VHF Radio Check
Don't know about the U.S. of A, but downunder the CG are happy to respond to a radio check request, as long as you keep it short and sweet. It's also comforting to know that someone with the means to rescue you is actually listening.
haskindm
Re: VHF Radio Check
Coast Guard in US will not respond to a radio check. You are not allowed to make a general call to "any radio" in a non emergency situation. All radio calls should be directed to a specific receiver (VHF Marine is not CB). Make your call to a friend or a marina to check your radio or check from your handheld to your fixed mount and vice-versa (on one watt).
dodgeramsst2003
Re: VHF Radio Check
while I'm not sure about not being allowed to make a general call to "any radio" during a non emergency situation. I am certain that if this is a rule, its not enforced. Not everyone has friends out on the lake to make a call to. Make your radio check short and sweet, something to the effect " this is vessel (insert name here) calling for a radio check on (channel) over" Wait for someone to answer and if possible ask them for their location so you can see how far away you are being picked up. I once called for a radio check, got a comeback with loud and clear, asked for his location, turns out he was about 100 yds ahead of me in the channel, not a whole lot of help. Around here, channel 68 is used mainly by fishermen and charters, never had a problem getting a radio check.
dodgeramsst2003
Re: VHF Radio Check
Also forgot to add, don't make the radio check on 9 or 16. 9 is emergency, and 16 is the hailing channel.
dnitz34
Re: VHF Radio Check
Thanks to everyone who has responded to my question.
dnitz34
