Re: VHF radio help needed
Trace the TX circuit back. I bet it's one of those .02 diodes.<br /><br />I mess with CB's from time to time. On them, there is a 3 leg transistor (NPN or PNP could be either) that controls the TX/RX function. Sometimes if you get a steering diode (as I like to call them) shorted or open, it can cause that.<br /><br />Without the schematic, as you are aware, it's hard to tell.<br /><br />If the radio requires to be ground to TX, then obviously I would check grounding to the TX circuit. If it requires 2 of the mike wires to close, then the problem could be on either wire.<br /><br />The circuit is being closed somewhere. You could trace the circuit and maybe try the 'remove a component one-at-a-time trick' until it stops transmitting. Sometimes this is helpful in tracking down a bad component.<br /><br />Sounds like a good old fashioned circuit trace to me! (What a pain!)<br /><br />Good luck,<br /><br />H.
