VHF Radio Hums
Doin Nothin
I just installed a new vhf radio on my boat, but when I call someone on it they here a buzz in the background. My stereo speakers also humm when I turn the stereo on as well. Can anyone explain why this may be happening.
JB
Re: VHF Radio Hums
Yep, DN.<br /><br />Poor job of wiring. Wire directly to the battery.<br /><br />Moving to electronics.
n0ukf
Re: VHF Radio Hums
And consider running your power leads through a filter.
mathiasmorgan
Re: VHF Radio Hums
AmigaDragon has this one right. You need a "spark" filter.. like from radio shack or most any store that sells electronics. Helps reduce spark plug noise if that is what your getting. Helps frankly with most other noises as well. You also could have the noise inducing into your wires (in the case of the speakers). make sure your speaker wires are run as far from any other wires as possible or add a metal shielding on the out side and ground it to the radio. Note only ground the shield at one end..i.e. the radio. If you ground it at both ends it will do nothing.<br />George
