Re: vhf radio question please help
hello, in my experiences, the difference between RG58 and RG8 (RG 213) on vhf antenna systems when the length of coaxial cable has been 3 to 4 meters , has been zero, in my amateur radio home station where the coaxial cables are longer than 20 meters I have noticed a slight difference on tx output power, at the antenna feed point at vhf frequencies, and even more so at uhf frequencies, which of course do no apply to marine band vhf frequencies, but only use enough cable to connect the transmitter to the antenna, long coiled up bits of unused RG58 coaxial cable is a waste of money and may affect transmitter output power.A good rule of thumb is the higher the frequency the higher the losses and the shorter the cable should be, within practical reason,KIND REGARDS AND A VERY MERRY AND BLESSED CHRISTMASS AND A HAPPY NEW YEAR TO YOU ALL, PEACE AND GOOD WILL TO YOU ALL, GOD BLESS YOU ALL,
