Re: VHS Antenna Length
the length of a antenna used on vhf is related to the design of the antenna, is it a 1/4 wave ,1/2 wave or a 5/8 wave antenna, after correctly installing the antenna, as recomended by the manufacturer,the next most important thing to do, is setting the antennas SWR , thus enabling the maximum transfer of power from the transmitter to the antenna, VHF ,being mostly a line of sight communication frequency, it would be better to mount the antenna as high as physically possible, if you have a sailing boat, right on top of the mast would be the ideal possition, on a speed boat etc as high as possible on the boat or even a short extension mast will assist communications . always set your antennas for the lowest SWR.<br />Regards William Wright.
