patrickwebb
- Joined
- Aug 7, 2008
- 17
i have a 1960 25 hp gale (johnson) sea king, im having a problem at low speeds, im getting a viberation and it sounds as if the prop is bent but its not, its a brand new prop, it goes away when i get on the throttle a little bit more, but it sounds terrible when im at low speeds. This is not a cause of sea weed because there is not any on the prop when i am doing this, i have that motor on a 14 ft aluminum boat, but i dont think it should be viberating like it is, do you guys have any ideas of what it could be, i just replaced all the seals in the lower end, (not because of viberation, becase it was leaking) i really want this to stop, thats if it is a problem or not, i was told that it is perfectly normal, but find that hard to bealive.
Thanks for any input you may have on this problem i have!
Patrick Webb
Patrick Webb
