boatsmitty
- Joined
- Jan 4, 2004
- 22
My '89 Force 125 on a VIP 180CC has begun vibrating badly at low rpms (1500 to 3000). It runs smooth enough when I quickly accelerate from idle and when running full, but shakes the boat in the low to mid-range. Also it consistently dies when I shift it into gear without a quick transition to higher rpms (will not idle in gear). I recently had the carbureators cleaned and fuel pump diaphram replaced after a few years of very little run time. Jets were clogged. It doesn't vibrate much when out of gear. Question: will a magnetic field (donut magnet or primary circuit wire wrap) around the fuel line keep the gunk in the tank from plugging the filter and carbs?
