Hello. I have an issue with a repower. Started out with a 1989 350 MAG, s/n OC 409667.
Let me say that I have been "certified" w/mercury marine since 1983. Among others. Have been put through plenty of obsticles & other "hoop jumping", even had to stand corrected once or twice! LOL
The original engine had 1900 hours on it. Constantly having to do something. Valve job one year. The following year started getting water in the oil. Cracked head. Owner had enough.
We are repowering w/ the "stroker" version of SB Chevy. The place we bought from, their version of "partial engine", crank & pistons up to heads installed & valves adjusted. Fine, I've done alot of engine replacements to 1 degree or another.
Bottom line is engine has great everything, oil pressure, temp & charges all on known good test equiptment. BUT, it's got a vibration!
Drive off, no water going thru it. Just light it up & at 1500- 2000rpm it's pretty significant.
It does have the 8" balancer (external) & original flywheel. All the research I've done leads me no where, ever been there?LOL
Thought maybe some merc techs have experience with this!
Thanks
Thanks
