vibration issue
marty f
i have an 1995 johns 115 2stroke and when at low speeds and am getting intermitet vibration thru the boat about every 3 seconds whats the problem
tashasdaddy
Re: vibration issue
no it maintains clean carbs, but doesn't clean dirty ones. sounds as if you are getting a lean sneeze, which means it's not getting enough gas thru the low speed jets. and they are not adjustable.
Kevin W
Re: vibration issue
has the prop been damaged?
an out of ballance prop can do that.
marty f
Re: vibration issue
is it hard to clean the carbs i have only done carbs on an snowmobile how difficult is it?
