I have read the reasoning behind the crack (corrosion building up between the propshaft carrier nut and threads) and I am going to get mine fixed but I had a few questions 1st.
My crack is quite substantial but it hasn't made it up to the gear case yet. The fluid is perfectly blue with no water intrusion.
Since the crack is large the propshaft carrier nut has to be out of alignment from where it was at the factory. Do you think this is causing my vibration/shutter at low RPM's? If you go above 3000 rpm then it smooths out and you feel nothing. If the motor is in neutral then you feel nothing.
My plan is to drill a relief hole right at the end of the crack, then soak down the carrier nut with PB Blaster for a day or so. Then back out the carrier nut so hopefully I can get the crack to mesh back together as close as possible. Then have my metal shop weld it back together and grease up the carrier nut and threads so it doesn't happen again.
If you don't think this would be my shutter issue, then maybe I will just drill the relief hole in the crack and leave it alone and search for the shutter somewhere else.
