LiFeStArTs@FoRtY
- Joined
- Jul 19, 2011
- 55
As the title says, I'm getting some vibration on my new to me Cruisers in my signature.
Symptoms:
Will vibrate at 1200-1400 noticably and at cruise rpm, not as much.
The vibration is like BRRRRMMMM...BRRRMMM...BRRRMMMM. IOW, it pulses for a second on, then maybe 1/2 to one second off. Boat performs well regardless.
What I know...
The PO did great maintenence including gimble bearings on both drives, impellers, greasing, fresh oils, and so forth. Also, within the last year, all bellows on both drives where done. I feel confident that there's nothing wrong with the drives and suspect the props might be out of balance.
I do NOT have counter rotating out drives... they both go the same direction. The props are 19 pitch 4 blade aluminum made by Sola if I remember correctly. I believe these were new in 2001, again going by memory.
I'd like to send these out to get freshened up but can't be without them for that long.
To the pros out there, does this sound like a prop issue or something deeper?
Symptoms:
What I know...
