Vibration when turning.....
dragracer
We just got our boat last year so I don't have much mechanical experience with it(yet). I noticed last year that when I would make a fairly high speed turn that somtimes I could feel a vibration throughout the boat. It was not very bad, but it was definately noticable(to me). I'm guessing some sort of u-joint problem maybe? Could it just be that the engine is trimming too high and causing this?? Can anyone help an I/O dummy? :confused:
Trent
Re: Vibration when turning.....
Mercrusier? If so, Yes u-joints. Common.
dragracer
Oops sorry....Yes Mercruiser....'91 AlphaOne <br /><br />Are the u-joints hard to change by a fairly competent shadetree mechanic?
Trent
Not real hard. Napa autoparts can get them also. Just take your time. Make sure to get replacements that have grease fittings. They changed to un-greasable around your year model. Remove drive every year and grease. Make sure to get the outdrive gasket kit. If you need the part numbers let us know.
