burtonrider11
- Joined
- Jul 28, 2005
- 178
After spending a lot of time researching and hands on work, I finally have our Starcraft 2010SS/5.7/A1G2 starting and running wonderfully. My only issue now is I am sensing more vibration while underway in no wake zones than I remember last year. Typically from about 1200-1500 RPM. I don't notice much if any while on plane regardless of mph or RPM. This was our first time out since last year. I did nothing to drive other than remove the prop, grease zerk fittings and store all the way lowered. Engine idles smoothly when on muffs in the driveway, so I don't believe it to be an engine issue, although, perhaps it wouldn't be bad to check the motor mounts?
I did add smart tabs (which work AWESOME by the way) and I can't imagine these would add to the vibration. The only other thing I think it may be (aside from something internal to the drive) is that the prop has an older hub kit that doesn't seem to going together like it should IE I don't have the screw on part hitting the threads on the hub. Current prop is an Apollo 14 X 22 4 blade. I am going to try to swap props with a new hub kit and 3 blade Turbo 21 next time out.
There is no chatter from the drive regardless of steering or trim direction. Everything shifts smoothly and accelerates nicely. The vibration isn't terrible, maybe 3-4 out of 10, 0 being no vibration, 10 being teeth rattling. But it was enough that my wife noticed it and I did too. The boat has always had a slight vibration at these speeds/rpms, it's just a tad more noticeable now....
Just want to nip anything in the bud prior to it becoming catastrophic....Anything I should check and/or lubricate? U-joints? Gimbal? I've never pulled the drive, but I am working up to it eventually.....The drive probably needs a new impeller and simple service in the near future....
I appreciate any advice.
