Void in newly laid transom????
santa666
Ok, after several months of cutting marine grade 3/4 doug fir plywood for my complete gut rehab of my 17' speedboat, the day came to install the new transom. <br /><br />The pieces, which I fully encapsulated in polyester resin all fit snugly, and were ready to go into the transom. <br /><br />I dutifully slathered each piece in the appropriate resin and wedged them in. I applied the "C" and bar clamps and motor mounting bolts to tightly secure the pieces into what I'd hope to be a monoblock transom...<br /><br /> After a complete cure I notices a hollow spot near the bottom edge on the port side. Tapping with a hammer revealed an unmistakable hollow void. <br /><br />I am dissapointed over the hollow spot taking into account how much planning and effort went into making it as solid as humnaly possible. <br /><br />The void is is about a 6 inch circle X 1/8 of an inch. It is not accessable except by some destructive method like drilling through the skin of the transom to "pocket fill" it (2 holes), or through the top down... (2 holes), or throught the interior plywood, (2 holes)...<br /><br />Should I try to fill the void? Will it flex, crack, and leak? <br /><br />I have seen this method in several books and have cross researched it on the web. Its a proven method involving an 8 Oz. sryinge with some vinyl tubing to force the resin into the void. The second hole is to let the air escape and will overflow when the resin has reached the capacity of the void...<br /><br />Is it worth the trouble? <br /><br />P.S. The boat is recieving a late 90's Merc 115 (not Opti) replacing a dinosaur 1968 Evinrude starflite IX 80 H.P. (complete with wood panelling accents, funk factor 10!!!)<br /><br />Thoughts?
crab bait
Re: Void in newly laid transom????
poly resin ain't a glue especially wood..<br /><br />i'd drill an rout/zip the void's outter skin .. fill back with epoxy putty.. saran wrap a scrap,, prop/wedge tite to keep putty put..
CalicoKid
Is the void between two layers of plywood or under the inner or outer glass skin?
andy6374
It won't flex, but the void will accumulate moisture and water.
santa666
The void is in between the new inner layer of (encapsulated) marine grade plywood and the outer skin. None of the voids surfaces are in contact with any of the encapsulated marine grade plywood, just resin and fiberglass...<br /><br />to andy6374: I cannot see how the void would accumulate any moisture, it is COMPLETELY sealed off on all sides with resin and fiberglass...
qaztwo
Had same problem, used a epty caulk tub that the local boat store sold, drilled several holes through the inner transom and injected a mixture of epoxy and milled glass. Solid as a rock, only took an hour.<br /><br />good luck
santa666
Must've been some trick to go through the inner transom layers and not have the drill bit punch through the skin layer...<br /><br />Then again, if you made it you'd know exactly how thick it was and when to stop...
CalicoKid
I think I would be inclined to do something similar because I would want to avoid cutting up the outer skin and repairing it. You can get drill bit stops that clamp on your bit with a set screw, or you can use some tape around the bit as a gauge and a light touch.
BrettNC
Drill a hole, fill it in. No big deal.
surlyjoe
once you get the epoxy in, drive a few small screws through the outer skin into the ply to suck it together, you can remove them once its dry and fill the holes along with the ones you drilled for the goop.
