voltage draw
NOSLEEP
Good day! My 1985 120 evinrude looper has a<br />voltage draw that I have isolated to the motor<br />its self.It draws power at all times when battery<br />is connected and very slowly drains the battery.<br />I have also determined that the charging system is<br />not charging at all. It did charge last season and<br />I am thinking that the two problems are related is<br />it possible that the rectifier has failed and now<br />draws constantly from the battery whether the key is on or off? Any ideas would be appreciated.
sparkroost
Re: voltage draw
You got it! There is 12V inside the motor on the terminal strip at all times.. and the rectifier is connected to it. I don't know if you have a regulator or not, but this can be the problem as well.
