BornBlue82
- Joined
- Feb 11, 2013
- 59
I just recently purchased a 01 bayliner capri sport with the 4.3L engine. I replaced the battery and serviced everything before taking it out for my first time. The guy I bought it from is a friend of mine, who told me that he notice the voltage problem. So that was a known problem to me. Which is also the reason that I replaced the battery. So when I took it out, everything worked great. However, when I advanced the throttle wide open I noticed the voltage dropping. It took about a little bit (don't know the exact time) to get down to low voltage range, then the battery light came on and the alarm sounded. I then cut the throttle back down the idle and the voltage rose back to btw 12 and 13. I removed the alternator to take it to advance but they said they didnt have the code to test it. Has anyone else experienced this problem? Could it be anything other than the alternator?
