Voltage force 125 1986 engine
bjhc100
My fishfinder has a battery voltage display, is this a satisfactory way to generally monitor electrical out put. Or should I check it with a meter at the rectifier. May be hard to do underway. Any ideas? Harley
QuadManiac
Re: Voltage force 125 1986 engine
Your fishfinder's display should be just fine. If you want peace of mind, check the voltage at the battery with a multimeter and compare to the fishfinder.
