Voltage Question
C17LoadSmasher
I have a 2001 Mercruiser 3.0L with a Alpha 1 Gen 2 outdrive. I took the boat out today, and the voltmeter is indicating slightly below 13V while the engine (and alternator of course) is running. I believe it should be higher, usually around 14-16V while running. What could cause this, or is it normal? Everything was 10-4 the last time I had it out (two weeks ago).
Dunaruna
Re: Voltage Question
Alternator could be faulty (not charging) the battery will still have good voltage until it runs down from starting & accessories. Check voltage at alternator not the battery - this will tell you if your wiring or connections are o/k. The voltage gauge is usually quite a distance from the battery and its not unusal to get a 1 - 2 volt drop in that distance. In other words your alt could read 14v but your gauge 13v.<br />Happy boating
C17LoadSmasher
Well I went and pulled the instrument panel and got my trusty voltmeter to see what it read at the panel. It appears to be the actual gauge itself. I get 11.4-11.7 VDC with key on, and with engine on, 13.7+. Is this a good measurement? I didn't check it at the alternator, it started to rain, so I put the boat away. I am going to the dealer on Monday or Tuesday, and will see about a gauge replacement (my understanding is that the gauges themselves have their own mfr warranty).
Trent
Easy check... Just check at the battery. With engine off and key off check battery voltage. Then crank engine and re-check. But make sure you rev the engine to 1500-2000 rpm first. Why? The "come in speed" of the alternator is somewhere in that range. Now if the voltage goes up then the alternator is charging. Should be 13-14.5 volts. Now look at the gage in the instrument panel. Does it also go up before and after the test?
akriverrat
and if you get good readings at battery it is usually corroded connections between it and gauge.
