I believe I have found the source to my charging problems. The red wire coming out of the voltage regulator is completely corroded. One is on its way but I'm curious if I can expect better performance when I replace it. The motor would draw the voltage down on the batt. it would be around 12.8 until i cranked it up then it would drop to around 12.4. My old motor would put out around 14.5~15 volts, and push the boat much faster (approx. 10 mph faster). Am I being too hopeful?
