capslock118
- Joined
- Apr 27, 2009
- 249
Hi All,
1990 V6 135 HP 2-stroke mercury ob
I may be having an issue with the regulator on my engine overcharging my battery. I will be conducting tests over the next few days using my multimeter and the instructions in the OEM service manual.
My question is out of curiosity:
In the assembly diagram, there is the "regulator assembly" and the 'voltage regulator'.
The voltage regulator sits on top of the engine block while the assembly is mounted on the side behind the trim solenoids and ignition coil assemblies.
What is a regulator assembly versus the voltage regulator? I know the voltage regulator is suppose to..well..regulate how much voltage is sent to the battery during charging; I don't know what this regulator assemly is or how it fits into the larger picture of the electrical system; or if I should be testing this thing as well. I do have questionable performance out of my trim solenoids so I wonder if this thing has something to do with it...or is it just a mounting point?
Thanks for your input.
