Volts checker
chumbucket
Need to pick up easy to use gizmo to check volts on batterys??????// thanks
twwmm
Re: Volts checker
multimeter from tandy maybe can get cheap ones to measure voltage
chumbucket
Re: Volts checker
Thank You mate, in 1976 we were steaming to perth but never made due to another ship in touble
shorenomore
Re: Volts checker
Try Sears. Good selection and they stand behind their products. You want a Voltmeter or Multi-Meter. Either will do what you want
twwmm
Re: Volts checker
multimeter is handy you can use the ohm meter to check fuses etc ;)
almost retired again
Re: Volts checker
HI Chumbucket,<br />Harbor Freight Salvage has some low priced ones that work very well. They also have an on line catalog.
