Re: volva penta prop
Without prop size it is very difficult to judge any of your specs.Prop numbers should be on the hub or barrel. -- X -- Diameter X pitch.
If 3,800-4,000 is with a typical load it would be good to get it to around 4,400 this would give you a little rev room when lightly loaded you can throttle back if it seems to exceed max recommended.
if 38 to 4,000 is with one aboard assuming it has the correct prop you need to check the engine; well tuned,check compression,is throttle opening all the way?Prop in good shape.Just a guess boat lightly loaded prop would probably be a 19 or 21 pitch with speeds approaching 40 mph.
An inch change in pitch will yeild about 200 rpm higher number pitch decreases rpm, lower increases.
