Volve Penta 3.0 overheating and losing power
Burcham164
I took my 1996 Caravelle with volvo penta 3.0 out yesterday and after I got on plane I noticed I was losing power so I shut it down. I could see smoke coming from the engine compartment. I noticed the exhaust riser bessel had melted due to the overheating? After it cooled off it cranked right back up and ran fine without overheating at idle. ( I did this after I got it home and hooked the muffs to it) What could be the problem? Impeller? I checked the oil and It does not have water in it.
tlewis1
It probably ran fine on the hose as you are using the pressure to supply water to the pump but when in the water the pump does not have enough vacuum to supply cooling water to the engine.
I'd be pulling that water pump apart and have a look at your impeller...it is probably in pieces. Next step after that is to a compression test to make sure you didn't warp the head when it overheated.
start with replacing the impeller
its a replace every 2-3 year thing
youre going to need to replace the exhaust hose too.
Burcham164
Thanks for the quick response guys! The fist thing that came to my mind when it happened was the impeller! Hard to believe those little things can cause so much trouble!
a $1 o-ring took out the space shuttle
