twozeroone
- Joined
- Jul 13, 2010
- 15
Hello,
I have a Volvo 275 outdrive. I'm new to boating and am just learning how to effectively use the trim. The previous owner said that when he put the trim all the way down and the 2 clips that are spring loaded clip onto the bar at the bottom of the outdrive it has and issue unclipping unless you get out of the boat and pull it up a bit. Is this just a spring tension problem? Do I just need a couple new springs? What is supposed to make the clips unclip when you push up on the electric trim switch to make the outdrive unclip and go up?
Thanks,
Scott
Thanks,
Scott
