Tommywalton
- Joined
- Apr 23, 2010
- 170
I have a 275 drive and after replacing the impeller i cant get the thing to pull water up from a bucket to the engine. I have the lower unit in a large bucket with plenty of fresh water. when i run the engine it will not pull water up. the impeller is good. when i put the water hose into the hose leading to the lower pump the system works fine. it wont pick water up through the unit. this is my opinion. the boat either needs muffs to force it up or put in the lake and once moving the water will begin to circulate. once circulating the system will work. does that sound right to you guys or what? does the water lower water pump on a 270 just "circulate" water with litte pressure or is it supposed to be pumping like mad? thanks
